BrotherJoe
Hi All!
My 3020 Diesel needed a starter. I was able to get a reman locally from a reputable source and I have the following symptoms that I'm puzzled by.
I got the starter put on, wired up, and connected R and L batteries back up and fired it up. Starter worked great; tractor fired right off. Shut down, re-started, started right up again; 3rd time tractor started up, but, starter continued spinning. Fortunately I had the RH battery loose still and was able to pull the terminal off and stop the starter and then killed the tractor. I checked everything over again, starter will spin (but solenoid does not engage) when I connect up battery.
I pulled the ignition button terminals, still, starter spins when batteries connected. Checked all wiring over again, not sure whats up, still.
Pulled starter off again.
On the bench I an fire the solenoid independently by getting to the 2 small terminals on the back as you'd expect, can spin the starter independently from the 2 large terminals on the starter (eg: not through the solenoid).
I'm puzzled as to why on the tractor it's wanting to spin when terminals are connected. What am I overlooking?
Thanks,
J
Thanks,
J
