onalaskahoe
This message is a reply to an archived post by onalaskahoe on November 15, 2008 at 09:43:08.
The original subject was "310A backhoe Hydraulics".
I have the same problem.
Try this, If I move the dipper out ( this makes more fluid return to the system then is being used) I can hear the pump load a little better and the hydraulics get fast and strong for just a moment. It makes me think that there may be a bypass valve leaking and that by having the higher return amount it loads the pump correctly.
This also makes me think that the main pump is fine and that I still need to find the place where the fluid is being lost.
