A few years ago I bought my 311B LP not running. Before I got it running, I opened each drain plug to check for water and a pin fell out the torque tube drain. The tractor has triple range, remote outlets and optional 3-point lift. The inside hydraulic hand control lever is broke off and previous owner had connected the outside lever to control the 3-point lift and disabled/removed the remote valve linkage. Originally I thought the pin that fell out, approximately 1/4" x 1", had something to do with the disconnected remote hydraulic but now think it is a clutch lever link pin from the hand clutch. The hand clutch works okay so PO may have replaced the missing pin. My questions are: 1. Would the hand clutch work with a link pin missing? 2. Can I see if the pin is missing by removing the triple range cover? 3. What other models use the same inside hydraulic hand control lever (G1103 in parts manual)? 4. Where can I get a replacement lever?
