311B ring gear
Cliff Nelson
Does anyone know where I might find a useable starter ring gear for a 311B? Part # is G11274, 124 tooth. Not sure what else it was used on but can check if you know of something. NLA from Case. I would be happy with a used one that I could turn around. The one I have is worn out on both sides. Thanks for any help you can provide.
I don't know if this is worth pursing or not:
This site: https://avspare.com/spare/case/g11274/
Lists G11274 ring gear for these machines: 320, 400B-SERIES, 310C, 300B-SERIES, 300-SERIES, 420
I only looked up the 320 and it does list G11274 ring gear
You will have to use CaseIh industrial parts site to look up some of these machines to verify the p/n at this link
below
Joe
http://www.rpmmachinery.com/case ce parts.php
I see 2 options, use the 96 tooth gear which we stock, used on the earlier 300, or simply flip your gear if the un-used side is good.
Ring gear has already been turned and worn out again. Can you email me your phone #? I'd like to talk about switching to the 96 tooth gear and starter drive. Thanks
