3130 tranny /hyd. fluid
leeallen3
I have a 3130 JD and plan to change out the tranny /hyd. filter and replace the long filter screen as well. What is recommended for a replacement fluid? Also - how many gallons does the sump hold. Thanks in advance.
Operator's manual has all the numbers . If there is not a JD manual here on Kim's site . Call --800-522-7448
Don't waste your time with an IT manuL.
(quoted from post at 20:38:23 12/03/15) Tractor Data's site states 12.9 gal.
It's very difficult to drain out all hyd fluid after the tractor hyd system have been operated. My guess is it will hold between 8 & 10 gallons when changed.
filter replaced, screen cleaned, refilled with Hygard. I recently bought this tractor, so I wanted to be sure the hydraulic system was clean. It actually looked like a service had been done on the tractor not that long ago.
