3220d Hyraulic Leak
Eradan-HT
My 3220 has sprung a leak! Thought it was the inspection port on the side of the trans, re-filled and proceeded to move it. No leaking while stationary but started leaking from the top of the trans somewhere under the tunnel. I have no disassembled to being diagnosis yet, just wondering if anyone has experienced anything and may be able to point me in the right direction? TIA.
If it only leaks when in gear then it is likely something in the powershift valve. You will need to do some more investigating to see exactly where the oil is coming from. It is not a common problem.
<ATTACHMENT filename="3220.JPG" index="0"><s>[attachment=0]</s>3220.JPG<e>[/attachment]</e></ATTACHMENT>
