325 dual loader oil weight?
J190
I have a 325 dual loader. After changing hydraulic oil and filter it does not have the lifting power and is quite slower. before i changed oil and filter it worked really well. I put medium weight oil in the reservoir. Should it be heavy duty weight oil? Thanks
Everything I own gets UTF in it's hydraulic system and if it doesn't work, it gets repaired/rebuilt/replaced.
Where are you? Does it get cold in the winter? The older DuAl cylinders are leakers, so the heavier the oil, the less they leak. I use 15-40, but it's mighty stiff until it warms up in our Northern Iowa winters. Sometimes I switch to Hy Tran or something lighter like it for winter use but if I leave it in for the summer it starts dripping pretty good. Jim
