rrlund
I've got a 4 row 333 No Til Special planter that I've had for a dozen years or so,so it's not new to me. I CAN'T keep that miserable thing level. It started acting up at the tail end last year,so I took the left side 2 way cylinder apart before I started planting this year. Figured the o-ring in the middle was bad. It wasn't. I got it leveled,seemed to be OK at first. About every other fertilizer fillup,I was having to open the leveling valve,level it,then close it up again. That went to every fillup,now today about every ROUND. If that POS would burn,I'd set fire to it for sure. I've even tried it with 2 different tractors. In fact I think I've destroyed the hydraulics on one tractor because of it,but that's another story.
Any ideas? There's no rhyme or reason for it.It has the stock factory cylinders. If you leave it up while you fill it,the left 2 way cylinder settles. When you're planting,raising and lowering it,the right side one way cylinder will stop going all the way down,but the 2 way does go down. I can't keep this up.The vent plug in the one way is clean. The only thing I haven't taken apart is the marker control switch,but that works fine,so I can't see what that would have to do with it.
