340 Loader Hydraulics Revisited.
L.Fure
I had posted earlier about the control valve for the Wagner loader on this tractor. It didn't have a float setting for the boom cylinders. I purchase a new valve and ordered the power beyond sleeve I needed. Everything is installed and working fine. I had one problem though. The hose that comes from the transmission mounted pump was attached to a aluminum pipe via a compression fitting. I didn't have a big enough wrench to tighten the large nut, so I had to improvise. As you can guess I didn't get it tight enough. While I was testing the new valve the compression fitting came apart. It pumped a gallon of hydraulic oil out onto the floor before I could shut the tractor off. I made a trip to town for more oil, bag of oil dry, and the proper size wrench. I sure hope I have it tight enough now. I'll be thinking of that fitting every time I use the tractor.
(quoted from post at 16:16:32 01/24/15) If it bothers you take it off and put a crimped
fitting on it
Do you mean a flare fitting? Can a 3/4" aluminum pipe be flared?
