gears
Ok, 3cylinder Gas 8speed, single clutch, no live pto, 15 spline.
It turns out if you leave your timing cover off (you know, the little sheet metal tab that blocks the 3/4" X 1" access hole to the flywheel for setting timing) mice can get in there and FILL it with nest that absorbs water seeping through the same uncovered hole to the point the clutch, pressureplate and even the flywheel look like they've been on the bottom of Lake Erie for the last decade!
Anyhow, I have a Loader on this tractor, it has a 12" clutch - do I NEED a 12" clutch? the 11 inch is much cheaper and more readily available. If I'm changing the pressureplate and disk shouldn't I be able to switch to the 11" unit?
I also notice in the manual that the "new style" replacements for the 3000 are the 3 puck triangular discs. Can I put one of those in?
Any advice or cautions?
