gears
So the little braided hose that goes from the grease cup outside the bellhousing to the throwout bearing allowing you to twist some grease into the bearing and slide assembly is NLA and mine crumbled.
An hour at NAPA and I couldn't find anything, the bearing is a 5/16" - 27 tapered thread (they were thinking 1/16" NPT) and the other end is a 3/8"-NF bolt that the grease cup attaches to.
Solution? I cut the crimps, and replaced the broken hose with a section of Air Brake line. Heated it in a cup of boiling water and forced it onto the nipples. A wrap of safety wire should keep it secure.
It held pressure when I greased everything so I think I'm good.
