3400 ford industrial tractor
Bucksmith
I was using my 3400 ford today and after about a half an hour the 3 pt just quit going up. It is in the down position with small disk. It doesn't want to move at all. I took the disk off and it still doesn't do anything. It seems that the fluid may be over full. Any ideas. This tractor is new to me.
Clogged inlet filter, pump lost prime, pickup tube from rear sump under RH pedal/running board rusted through & leaking or letting pump suck air.
I would start at the pump (left side of engine near steering column), pull the purge plug and see if you re getting fluid there.
There was nothing at the pump when loosening the bleeder screw.. I finally got some fluid coming and air. Bled out air and 3 pt arms went up and down until I hooked the disk back up. Once up and back down wouldn't go up again. Took a long time but finally got oil in the pump and once up with the disk and that was it. Where is the inlet filter? It seems like the pump has a hard time getting oil.
Top cover (seat & lift arms) needs to come off, inlet filter is down in the sump. You should have a manual. Email me if you need a copy. mantalek at kent dot edu
(quoted from post at 19:08:33 07/24/22) Top cover (seat & lift arms) needs to come off, inlet filter is down in the sump. You should have a manual. Email me if you need a copy. mantalek at kent dot edu
Could it be that the pickup tube seal would be weak on the pump and allowing air in. I'm thinking of the simple things before I go deeper into the machine.
