Otto Mechanic
Does anyone know if the tie rod style end on the rear of the steering ram can be tightend or adjusted? For some reason both of mine are loose, or are they supposed to be this way? Also the sterring seems to make a sound like it is always working even when not turning the wheel. Both outer tie rods need replacing as well as the play in the steering rams so I don't know if all this play is causing the steering to constantly make adjustments. I forgot to mention that the steeing ram tie rods are loose on the ram joint not the actual tie rod themselves. Thanks for any help.
