3400 Transmission Swap?
69-3400
Is it feasible to change the transmission in a 3400? I see there were options for more gears and an over/under drive. I have a 4 speed but it moves faster than I would like when brush hogging in tight areas especially since the PTO is connected to the clutch.
Yes, Any transmission from any
2000,3000,3400,2600, 3600 tractor is a direct
swap.
Make SURE you also get the flywheel and clutch
that came with the transmission as Ford used a
bunch of different ones.
Also, if you go from a single stick
transmission to a double stick you will also
need the pto shaft, pto sliding coupler and pto
engage handle.
