3400 wont start
cdv
got a 3400 today and it wont start ,,120 compression in each cly,, real good spark at the plugs,, good gas to carb but still wont start seens like it starving for gas butt took plug out of carb and gas pours out nice,, any ideal what it is thanks cdv
Might be retarded. You should put it at top dead center cyl #1 and pull the distributor cap and see if the rotor is lined up with #1 post on the cap. put a mark on the distributor housing where #1 post center is, and it will be easier. You might need to turn the distributor to a more advanced position. Hard starting is a sign of retarded timing.
First a question. You say you just got it and it won't start. Did the seller start it for you before you bought it and now that you have it home it won't start? Or was it sold to you as-is with the seller saying that he couldn't get it to start?
A gasoline engine needs four things to be able to run: Fuel & air mixed at the proper ratio, sufficient compression, and good spark at the correct time.
Good gas to the carb doesn't necessarily mean good gas and/or air to the cylinders. Have you pulled the spark plugs after cranking the starter for a while to see if they smell like gas? Have you pulled the air filter to make sure that it isn't clogged? Have you been using the choke? Have you checked to make sure that the choke cable is actually moving the choke mechanism at the carb?
ran great when I looked at it last week..,,choke is working,,air breather hose is off for now ,,,didn't pull the plugs used a test plug lots of compression ,,should be in time ran good last week thanks cdv
Probably still has the Holley carb.
FYI, unless the tractor has had the fuel pump removed from the system and is running on gravity flow draining the gas from the float bowl is not a good test.
if all it does is turn over and does not sputter, cough or partially catch fire I would think electrical. my favorite thing to do in such a situation is put a new condenser in. cheap and easy. doesn't always work but when it does it saves aggravation.
Like Sean says. Take a spark plug reading before going too far, in order to ascertain gas and spark.
My 3400 gasser has been hard to start on these cold mornings, but with jumper cables attached she fires right up. Troubleshoot with the easiest things first.
