350 diesel injector pump
Rftlts
I need to pull the injector pump and injectors to be cleaned/ rebuilt. does anyone have the manual for this engine. I need to know of any tricks or things to look for or do.
exspecially regarding the timing.
thanks
Loren
The pump has timing marks under the two screw cover on the pump side. Remove the cover after turning the fuel off at the tank. When fuel stops coming out the pump, there will be a stationary mark visible. Turn the engine by hand until the weight retainer mark is aligned with the stationary cam ring mark. Remove/replace in this location. If I recall there are marks on the front pulley also, will need to check the service manual to verify correct timing. Last IH 350 pump I had in for repair was six months ago, don't see those very often. That one also needed new injector tips.
