Posted a few days ago about a tractor am looking at. A neighbor has it and thinking about buying. I found out it is a 350 row crop when I went back and looked at it. It is not runing a this time and I don't know how long it has been since it ran. The engine is a C175 but the 175 is stamped in and you can see where the original casting was ground off and then stamped. Is this a reman engine?
Wanted it to fix up but pulled dip stick and seemed to have water in oil but engine is not locked up. I shifted it into 1st gear and then could not get it to shift out. Wanted something to fix up and not a parts tractor so not sure now if I will buy or not. Quick hitch, tires hold air but not good for $500??
