350 flywheel
Will bolt to crankshaft. If installing the c-175 in a H yes. Crankshafts are the same size other than most H tractors had smaller main and rod journals than real late H through 350. If wanting to use on a 350 the clutch disc or pressure plate won't work on a H flywheel and starter ring gear is a little different distance from back of block compared with a 300 or 350.
