Paul 300 U
After rebuilding the steering I got the power steering working and then,after a split got the transmission sorted out on this tractor. A little bit of electrical work and rebuilding the carb got the tractor working fairly well. At the end of winter while using the loader to move snow, the steering went out again. New issue this time. The Lever Shaft with sector gear has a broken tooth. It's number 43 in the diagram below. Apparently its been welded before. The guy that does my welding doesn't want the job because it's cast and he says it probably won't hold. Of course the shaft is hard to find used. I'm open to opinions on welding but here's my question. In my search for a replacement what utility models use the same shaft. I know the 300 and 350 are interchangeable and does it matter whether the shaft coming off the donor tractor is manual or power steering? I don't believe so but I'd like to be 100% certain. Thanks for the help! Paul
