Redpaint11
Ok guys, here’s the situation.
I had recently done a double split on this to fix the t/a seal leaks. I also pulled the hydraulic cap off and the rear end top plate to clean out the rearend and the hydraulic reservoir (it was very dirty)
I had to replace the hydraulic filter screen because it was plugged, collapsed and had tears in it.
Everything went back together well. I previously noticed the fast hitch cylinder lifted very slowly and had a bleed down fairly quickly after the tractor was shutdown.
I assumed it was a bad control valve because I hooked up the fast hitch to the second control valve and it operated perfectly.
I got a good salvage valve and after cleaning it up and replacing the o rings got it installed. Unfortunately, it is the same issue. It will lift with the engine at 50% or higher power setting but it takes 2-3 minutes to lift. The strange thing is when I hold the fast hitch control to the lift position and then activate the auxiliary control the fast hitch works perfectly. I’m stuck. Any thoughts??
Much appreciated.
Much appreciated.
