350 utility... mounting a loader....HELP!!!
53H
I am helping a neighbor of mine with a 350 utility who wants to mount a loader on it. he bought one off another 350 utility so i know it will bolt right on, but here is where it gets tricky...the other tractor had 3 levers to run the fast hitch and the dual remotes, the one its going on has just one to run the fast hitch. he bought a new aftermarket 2-spool valve to operate the loader but i don't know where to plumb it in. I don't want to mess with the stock valve because he may want to use it with a back blade along with the loader so i want to be able to use both at the same time. I think running the return line should be easy, but I don't know where to tap into to get the supply for the aux. valve. anyone out there done this before?
The 350 has a semi-demand based system. it is open center to the valving, but uses a pilot valve to turn on pressure to the valves and steering. This pilot operation is necessary for continued use of the rear valve. The best might be to use the valving from the same tractor to do this. 300U or 340 330 350U will work. The other method uses a "power beyond plate in place of the blocking plate on the right front corner of the reservoir. It will give the needed pilot signal and allow remotes to be connected. Jim
