350 utility
the filler neck in front of the hydrolic pump...is that to fill with engine oil or hydrolic oil? if it is not for engine oil where is that filler neck?
mike
International 350 engine oil is filled under the "winged" cap between the pump and the fan blade.
The hydraulic oil is filled thru the check plug under the seat.
thaks alot, i just wanted to double check
also did these 350 utility's have a diff lock on them or are we just supposed to hold the brakes down on the spinning side?
