3500 Ford carb
I have a 3500 Ford 3 cylinder gas motor with holley carb. Runs good once it gets running sometime I have to give it a shot of carb cleaner and it will just fire right up . After it sits for a day or so I go to it with choke out and it will not crank give it one shot of carb cleaner and she fires up and runs good. The choke is working because when running i pull the choke out and it sounds like it is flooding. The tractor set for about a year with a bad clutch and i got that fixed now have this problem. I have been running some carb cleaner in the gas , the gas was fresh we drained the old out and put in new.
modern gas sucks big time. It will turn to puddy in side the carb... so you probably need to pull the carb and need to clean it...
does the tractor continue to run after you give it a shot, or does it then die.. if so. you may also have a plug in the line from the tank due again, to the bad gas...
Verify that the choke cable is adjusted such that the choke valve closes COMPLETELY.
Dean
