colo iron
I have a 3600 Ford farm tractor. I was unable to control the 3 pt. it would either be up or down. I drained the oil and it looked like it had moisture in it so took the cover off and it showed rust and some of the parts would not move. I replaced the ones that need replace and freed the others. I put it back together with new oil now the 3 pt will not raise unless I increase the RPM. When the 3 pt is raised it hold the position. So I drained the oil and put lighter oil in and the results is the same. This has the pump on the side of the motor along with the filter, which I replaced I need idea's on where the problem is and what I need to do to correct the problem.
Thanks for your help.
There's an adjustment knob that controls oil flow on the side of the housing under the seat, turn it all the way in to increase flow.
What oil are you using, tractor hydraulic oil is the recommended oil.
