362 Gas Engine Wanted
JDIHMM
I am looking for a John Deere late 362 gas engine. It was used in late 4020s and all 4000 tractors. Also used in 6600 and 7700 combines. The casting numbers will be R40670, R40680, R49530 or R49530. The casting number is on the block behind the starter. I would appreciate any leads on one near southern Minnesota. Thanks in advance
I have a 348 out of a 105 combine. It has M&W pistons and sleeves that supposedly makes it a 362. It did have a few more guts with the M&Ws when it was in the combine ut I have no way of knowing if it has factory 362 power. It is worn but still runs OK. I will let it go real cheap. I live between Storm Lake and Spencer Iowa.
The engine I’m looking for has seven main bearings. The
earlier gas engines had four main bearings.
