364 hydraulic trouble
The hydraulics on our 364 stopped working. The power steering works a little but not like it used to. The pump is a two stage pump. Does
anybody have any ideas what might be wrong?
Hi, so your 364 has two hydraulic pumps stacked one behind the other? If so then the only common thing is the hydraulic oil supply. Possibility the suction filter in the hydraulic reservoir is clogged or if it is cold in your area ice has formed somewhere blocking the flow of hydraulic oil into the pumps.
JimB
JimB is right I think. If you are lucky the filter is just plugged, if not the filter may have deteriorated and ruined the pump too. My B414 winch uses the same filter had ruined the pump because of filter rot.
