37 model Int square baler not tying
Pulled this baler out of my dads barn last year...sat for at least 18 years. Greased everything up, new string and once I got thru the first 4 or 5 bales, everything worked perfectly. Bales were tied, good weight on bales and felt like baler could have done 1000 bales that day. I ended up doing about 175 which was all I need for the year. Went back into the barn.
Side note...during the winter when I took the bales out of the barn, I noticed I had a lot of the strings broke..assumed it was mice as each string still had the knot and the break was about 5 inches away from the knot.
Move to last weekend....a neighbor wanted to borrow the baler. greased...new string...and at first was an issue with tying...then it would quite for a few bales then act back up...I was also told it was making a knot but when the bale dropped and was picked up the string broke..not within the knot but about 4 to 5 inches away. (same issue I had over the winter)
I saw a utube about a New Holland square baler...said there were several springs that could be weak or broke that could effect the tying, but was not sure if they were all done the same or not. Have not found any International utube videos.
I get that as things get older and sit around it gets worse...I am just surprised it did so well last year and like that it has issues.
So help with troubleshooting on
* if the knotter is not making a knot?
* why would the string be breaking about 4 to 5 inches from the knot?
* any photos would help
I am learning all of this from scratch and may not have all of the correct terminology but doing my best. thanks for the help
I can make some suggestions based on owning a model 46. Best suggestion is to get a manual. IH balers are touchy machines and everything has to be right to tie correctly. Does your baler tie and then come loose or just doesn't tie. Some things to consider: type of twine - I don't know if a 37 could use plastic, use 7200 if possible for sisal, 9000 will work but sisal twine these days leaves a lot to desire. My baler and probably yours does two has 2 hay retainers on top and 2 on the bottom that has a spring in them. They prevent the hay from backing up when the plunger leaves the chamber. The springs can get lost and the baler won't tie. There is a tension requirement on the bill hooks - too loose and the knot won't stay tied, too tight and the string will break pulling it off the bill hooks. All this stuff is discussed in the manual.
Are all of the breaks happening from the same roll of twine? That might explain the 4 to 5 inches from the knot, as in it's coming from a rotted place on the twine roll. Did you try a different twine roll? Also could be a sharp area on the knotter body that is about 4 or 5 inches away from the knotter itself.
IH balers are also known as "not so good at tying" as the "grapevine" says.
The manual will tell you to look for a sharp edge. I would be looking at the end of whichever needle is pushing the twine to that side.
I have an old #37 baler too, but have not used it for many years. At first I was thinking your problem was twine(and it still might be), but since it always breaks 4-5" from the the knot I doubt it is the twine. If the problem is only on one side I would think something is rubbing the twine and making it thin behind the knot. Like maybe where the twine runs under as the bale goes on into the chamber as the twine pulls out of the knotter.
I once had a bundle of twine in mine(on a Sunday) that ran thick and thin. You could feel and see it. The twine kept busting all around the bale, but it was defiantly faulty twine. Next day I got new bundle of twine and all was well again. Good luck, Mark.
