383 massey ferguson lights
I have a 383 massey ferguson tractor with cab and the lights went out the other nights and will not come back on. None of the lights except for
flashers will come on. Any suggestion where to start trouble shooting? I have only had the tractor about a week so I do not know a whole lot
about it.
fuses are not blown. I pulled the light switches and took them with me to work and had the electrician use his ohms meter. The switches checked out to be good.
out to be good.
(quoted from post at 07:23:02 12/10/17) fuses are not blown. I pulled the light switches and took them with me to work and had the electrician use his ohms meter. The switches checked
out to be good.
there is a relay behind the plastic cover on the dash sitting in the seat it will be the left side beside the heater vent take s a flat blade screw driver those are half turn screws four of them and the relay is the one closest to the winsheld I think the other one should be Ac relay try swapping the two also depending on what year model you have to turn front grill lights on to get the top front and back ones to come on
