I've got an old B that has been sitting a long time, pistons frozen. I ended up pulling the head in the field, filling the cylinders with various, and letting it sit. I finally got around to dragging it down to the barn. I've got it so it turns, the bores look good, engine is super clean inside. I put it back together, set the valves to zero lash, so I'd be sure they close. Fresh gas, flows, cleaned the needle and seat, gas is getting to carb, but no discernible spark.
FB model J mag. I took the caps off, scraped the points clean, reassembled, mindful of the chamfered teeth. Found TDC of #1 compression stroke, installed mag. I can't get spark to the end of the wire. Not a spark tester, not a screwdriver near ground, not a bare hand on screwdriver. I can feel a pretty good jolt with my hand direct from the coil, with the top cap off when the impulse snaps, but can't get anything from the plug wire towers. I've got couple more junkers in the tractor graveyard, but a different mag,and swapping caps between and around makes no difference.
I'm not too familiar with magnetos, if it was a battery/coil distributor I'd say I had a bad cap and or rotor. Maybe a coil that's weak. But I get not a whimper, backfire, or snort.
One of my theories is that I'm not getting enough engine speed out of it. It's a pretty stiff pull still. What do y'all think?
