Hi,
My friends Ferguson 390T is not charging. Belt condition was good, clean and tight!
12.29 Volts ignition off.
12.16 Volts Engine running.
I don't know too much about alternators, but with the 'engine off', I connected a voltmeter to each of the 3 terminals on the alternator which are under a connector.
Only one of those terminals are normally connected with a small wire - the smallest terminal of the three. At the small terminal that is connected no voltage reading - 0 Volts. However, battery voltage was present at the other two unused terminals. This was with the engine off - I didnt test it while it was running at those terminals as the connector should be connected.
Battery voltage also present at the large wire which I presume is the output feed.
Same voltage readings at alternator or battery.
Not sure if I was going the right way about testing it or not so please help. Is it possible to test/replace diode pack separetely?
Also the rev counter, fuel guage, and temperature guage are not working. The owner says these 3 problems occured at the same time. Not sure when it stopped charging as there is no warning light for that! Battery is still strong enough to start engine.... for now!!!
Rev counter is reading 5,000 revs with the engine on or off. Other guages are reading Empty and Cold! No loose wires or bad connections noticed around the back of the dash panel, or temperature sender unit.
Any advice please?
Any advice please?
