3point equipment for eagle hitch
For my reference, trouble as in the high hitch point on DC & SC when using PTO driven 3pt equipment right or is there another ideosincracy?
Jim
Jim,
On the SC-800s the top bracket under the seat was there for such things as 3pt mowers. For plows etc, you had to install the pto cober/bracket for the top link to get the geometry needed to lift the tail of the implement up and to work properly in the ground. The bracket under the seat was not that strong either.
Loren
Just keep in mind you won't get the full lift / ground clearance using non-case inplements. My wife's 51 VAI has EH and I have used ford / ferguson / dearborn implements on it for years,just pay attention and you should be fine.
Jim
I had to turn one of the pins to the inside on the rotary mower to get it to hook up. I think you may find the pins are too far apart on some implements and may have to be modified.
