TheOldHokie
- Location
- Myersville, MD 21773
I get a lot of calls about a hydraulic kits and conversions and it seems the topic of 3pt log splitters generally comes up. The usual knock on three point splitters is slow cycle time. It takes a substantial hydraulic flow to run a splitter at a decent speed and we all know that is not a strong point of Ford tractors. In fact its even a challenge for most modern compact and small utility tractors.
Now I have been running a 3pt splitter on my venerable old Kubota B7200 which has a puny 4 GPM pump. Very slow but at 70 years old its better than swinging a maul. I recently added a new L3901 to my tractor lineup and it has a 6+ GPM flow and teh improvement was noticeable but still slow. As chance would have it the valve on the splutter had developed a bad leak so I decide to replace it with one of the new "high speed" valves. These valves have a regen circuit on the extend port and a 4th position on teh spool that actuates it. When you pull the lever all of teh way forward the regen circuit speeds up extension at the cost of splitting power. As soon as the wedge stalls in the round you let the lever slip back into the third position where you get tthe full splitting force. Its the same idea as a two stage pump on a small engine spltter but its manually controlled and only works in one direction. I had my doubts but the valve was only $30 more and Iso I popped for it. I was pleasantly surprised at the speed up it creates. Here is a short video showing extend vs retract. Keep in mind extend is always slower than retract to begin with so the difference is quite startling.
TOH
YouTube 3pt Log Splitter Video (30 seconds)
This post was edited by TheOldHokie on 10/20/2021 at 03:47 pm.
TOH
