3pt lower pin install ?
yukon73
Help...bought a 52 8n that's in need of some TLC ! I have no reference point, missing both lower pins for the 3pt. New ones arrived today...arrived with a bushing nut on the tapered end and a locking washer and castle nut on the other side. Do you install it tapered end facing out or in, bolt outside the trumpet and washer & castle nut on the inside, do u need to pin it cause there is a hole for a cotter pin ???? Thanks in advance...
tapered to inside clean it up good and put a good coat of J B weld on the tapered pin before installing tighten with a good 1/2 in air wrench
then install cotter pin
(quoted from post at 16:55:08 05/13/16) Help...bought a 52 8n that's in need of some TLC ! I have no reference point, missing both lower pins for the 3pt. New ones arrived today...arrived with a bushing nut on the tapered end and a locking washer and castle nut on the other side. Do you install it tapered end facing out or in, bolt outside the trumpet and washer & castle nut on the inside, do u need to pin it cause there is a hole for a cotter pin ???? Thanks in advance...
