johnofnewhaven
A post below has me wondering. What ground speed is a good speed for a 3pt tiller? I am sure it depends on the soil condition and type.
It varies by ground conditions, type of soil and if you have rocks. I ran a 3 pt tiller for FFA in high school. In rocky conditions I ran very slow and it would toss rocks on top. After customer picked those off I came in and ran a little deeper and faster. Most times with rototiller you have to run slow to really get some depth and beat up ground.
My neighbor has a 50 hp massey with a 5 ft tiller.
The tractor doesn't go slow enough for the tiller to do a good job. The tiller tines rotate in the same direction the tractor wheels rotate. .
So I shopped around and found a 1997 JD GT275 with a 30 inch tiller, 48 inch mower for $1500. Better than buying a tiller. My Jubilee goes too fast for a tiller. The JD garden tractor is hydrostatic. Only 17 hp kawasaki.
The tines rotate in the opposite direction the wheels rotate.
Go slow and it does a fantastic job compared to what my neighbor's tiller did on his 50 hp massey..
The tiller digs itself into max depth, about 5 inches. It turns the soil into powder.
My friend had an old Wheel Horse Garden tractor with a tiller.
It too did a fantastic job.
Might think about finding an old Garden Tractor with a tiller.
I'm glad I did.
I bought another John Deere lawn mower real cheap. It needed a new mower deck. The tiller now stays on the Garden tractor full time and I have a JD lawn mower that uses the old mower deck..
Look for a tiller on a Garden Tractor..
Most older tractor go way to fast for a tiller. You need a very slow low gear but not sure what the MPH is. I do know most Ford tractor like say the 801 series go to fast
My 1950 8N has the Howard Reducer transmission that was built for the Howard Rotavator- you can walk circles around it, very slow in low-low
I run a 7 ft tiller behind my 4000SU, it runs about 1.2 mph in 1st gear which is a little to fast but a 2nd pass will make a big difference
A 3rd pass and it s making powder 6 inches deep
I change directions each time I go over it
(quoted from post at 15:57:00 07/11/22) My neighbor has a 50 hp massey with a 5 ft tiller.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto130257.jpg>
I'm glad I did.
Powdered soil is not ideal . It sets into one large solid block .
Some people run a V-ripper through the soil . It loosens deep for drainage but does not lift sub soil up into the top soil .
A Rototiller afterwards does work as hard or as slow afterwards . The soil is left with some texture instead of being powder .
My BCS tiller has a ground speed of a little less than 1 MPH in first gear & a tine shaft speed of 290 RPM. That combo gives a tine to tire ratio of 20:1 RPM, 10:1 RPM in second gear (2 MPH). First gear will turn the hard ground to potting soil in the Spring. Second gear is good for cruising along & lightly cultivating the top of the soil. Second is also good for keeping the tiller afloat, as it would just sink & spin in first in the soft ground. Also, first chops the ground up too fine & it will be concrete by fall unless you till all the time & it is not recommended to over-till the garden.
Mike
Is that Howard tied to a Sherman or Hupp? That will slow it down a bit more. Then you can get off the machine, walk up ahead, pick up the stick in the path and wait for the machine to catch up. Her '50 Fergy TO-20 has the Hupp, Howard combo so far with an Everett waiting to be added. The Everett being 98:1 ratio means bring a lawn chair waiting for it to catch up.
Thank you Destroked You answered
my question. I just hear and
read that a certain tractor with
a certain transmission is to
fast for a tiller but I never
see anyone say what a good
ground speed is. I get soil
condition has a lot to do with
it. I think now I understand
that 1/2 mph to 1 mph is about
what is needed for a 3pt tiller.
If you want to work it in 1 pass yes the slower the better but a few passes with a tractor doing 1.5 mph or less will still do a good job
I know my tiller is larger than most on here but it s added weight helps it to get into the ground
I ve had digging ground so hard it was sliding to tractor tires and lugging the engine down a few hundred rpm s, but on the second pass it was loosening up and starting to look good
When working ground I run a digger through it to loosen the ground up then run my 7 ft tiller with a packer on the back and have been getting good result. I run it 2-3 miles per hour with 60hp tractor. The packer firms the ground up so it up so its not too fluffy. I cultivate 4 acers of pumpkins with a 48inch tiller at about 2-3 mph as I just want to skim to top and kill any weeds. I don't like to turn my ground into powder.
My friend still has a wheel horse tiller.
He wishes he still had a wheel horse..
He blew up the engine 2x.
(quoted from post at 13:50:39 07/11/22) I just hear and
ground speed is.
I have many times described the speed at which you need to go as a "shuffle." 1st gear on most tractors is a leisurely walk, 2-3MPH.
It all depends on your soil and the number of rocks. I have a 72 inch tiller behind a 50 hp tractor THAT HAS A CREEPER GEAR. Here in WNY, .5 mph is plenty fast. I bottom plow and after it settles, I herbicide and rototill it. Just finished 2 acres of food plots.
