3pth to fast hitch
I have a Farmall 504 D with a 3pth and was wondering if there was any way to slide fast hitch receivers over the ends of the 3pth arms so that i could use fast hitch implements also. Is it possible? Does someone make them?
Don't think the 3pth arm are strong enough and, depending on what implement you are attaching, you might need to drill another hole in the arms.
I'd approach this problem by comparing what is different between the 504 Fast Hitch and the 504 3pth hardware. You could get either system from the factory.
If all you need is the wishbone plus sockets, lift links, and belly pivot and don't care about draft control, that might be a better solution. Goto the CaseIH on-line parts book to do your research.
I went to a salvage yard and got the yoke and 2 point tubes. I turned the yoke over and andpulled it up all the way over the tubes and wielded it solid added the 3point pins. drilled out the hole in the narrow end of the yoke for the 3rd link pin. No perfect but does work.
