4-star hydraulic controls
Hey guys working on the hydraulic unit on a four-star. Im trying to remove the hydraulic controls from the rock shaft housing. I see I need to remove the little internal hydraulic tube from the rear of the rock shaft housing. I have the bolt and the plug out on the back end where it goes 90 but I cannot seem to get it pulled out. Any trick on how to get a hold of that tube and pull it out of the housing?
The other end is a 90 with an O ring seal. Cant seem to get a hold of it to pull out.
Slide your block with the control levers off the studs then you can reach in the rockshaft housing with a prybar to pop out the tube.
