Hotflashjr
- Location
- Western MA
I got the starter off my 40U. It spisn freely in my hand including the Bendix. It did not seem lodged/locked onto the flywheel when removing. Engine turns over with a prybar on the flywheel like it should.
How do I safely test the original 6 volt starter? My thought is to put it in a vice, ground the mounting bolt of the vice to my battery with a jumper cable and then with the positive jumper cable tap the positive lug on the starter to see if it spins.
I also got the dash plate off and the wiring in there is not the best. I think a wiring kit is in order and might be the actual issue, not the starter, but want to verify the starter does spin.
