400 farmall TA
D Slater. I ask about a 400 TA that I was having problems with not going into low and sometimes going into high range with the stick back. You gave me some ideas which I thank you for. I took the High side clutch/pressure plate and TA flywheel to my shop after readjusting the TA and found out that the clutch and pressure plate was almost new. The problem was the finger on the pressure plate had to be adjust out towards the throw out bearing. Not really sure who did it but the were almost all the way in. Thanks for your help though. Ed
Good and welcome, For a good working T/A clutch setting the finger height before installing in the tractor is a good idea. From what I used to find its often skipped.
