400 had 12 volt positive battery when I got it 5 years ago. Have had no problems starting at all until last weekend. Went to start after tractor sat over the winter and no start. Checking ignition system had no spark at points then noticed smoke coming from the device between the hot wire and the coil. Device was also too hot to touch. This happened within about 3 minutes of turning switch on.
Any thought on what's happening here? I have 12 volts coming into the device and 6 volts outgoing. Does this mean I have a 6 volt coil? The device was on the tractor when I got it. Not too sharp on electrical ignition.
