400 Water pump driver photo request
PaddyO
Greetings,
Left the lens cap on when taking this part off tractor! ;) Does anyone have photo of driver and fan and pump assembled using the Eaton pump PS setup? I am unsure where the 5/16 nut (2) goes on longer bolt used in place of driver stud used on non-PS setups.. Would also appreciate a written description too!
Thanks in advance,
Paddy
No photo, but put spacer on long bolt, put bolt through driver, then install nut. Tighten nut so spacer is tight, then screw bolt through fan into hub. You may well want a flat washer against the spacer on both ends as well. I know you didn't say anything about spacers but they are supposed to be there for that application.
