4000 charging problems
Seth Roemer
I have a 62 ford 4000 with a new battery, wiring, voltage regulater, and had the gen rebuilt 4 days ago, my charge light went off. Went on a tractor ride yesterday and now when you give it gas the light comes back on.. Any help?
Is the belt howling? I'd bet it's slipping. Check the tension and see what happens...
If it is slipping you want to get that taken care of because water pump function will also be very limited with a loose belt.
Rod
check the gen itself by removing field wire and jumping bat to field, see if gen makes full power at battery.. if not, also jumper cutout.
if gen is working good, look at vreg
post back
