I’ve got a 1968 Ford 4000. 3cyl has with the select-o-speed. I’ve got a persistent hydraulic leak I decided to investigate today. I thought hydraulic fluid was leaking from the platform mount on the right side (brake side). Every time I fill up the reservoir I get a leak coming from right around my right heel. I took the platform off and the leak is coming from this bolt above the rear platform mount. I pulled the bolt out and it’s about an 1.5” long 1/4” bolt but it has a tip on the end similar to a slotted screw driver. Thing is, I can’t get the bolt back in. So what is this bolt? I’m assuming it has something to do with the hydraulic system. How do I get it back in?
Here’s a pic:
It’s the bolt halfway out above those 2 mounting holes.
Here’s a pic:
