4000 rim and wheel
I have a 4000 4cyl. row crop I just bought. One rear rim is a power adjust , the other has been swapped out. It has a new style wheel that can only be dished out. When I
try to rotate it inward to narrow this side, it will not fit over the brake assembly. Wheel and rim have both been changed on this side. My question is what other
tractors would have the same wheel as a row crop? Is the utility the same? Are 600-800-900 series same? I dont need power adjust, but I would like to be able to narrow
this tractor to run a small brush hog. Before I start calling around to find a used one I need to understand what I am asking for. Thanks, Al
The 4 cylinder 4000 row crop model came equipped with the Ford 28" PA rims. This system is the same as any vintage Ford tractor made between 55 and 64 and equipped with PA rims so any will interchange. 8/9** models used 11" rims as properly measured. Not sure about 6/7** models but believe that the vintage Ford PA rims were made only in 11" versions regardless of tire size.
That said, centers/rims from any vintage Ford AG tractor built between 48-64 (and some others) will bolt on.
Dean
What is the bolt pattern of the hub? Allis Chalmers and Massey Ferguson used 28" power adjust wheels on some models. They might fit your Ford.
Indeed, some AC and MF wheels will bolt onto vintage Ford tractors of the similar era.
The bolt pattern is the same but the stud size is different.
Dean
