johndeerefan
Since I have owned my JD 4000 diesel, it has always been a real pain to start in the winter months. My problem lays in that it only gets started about 1 time per month and ran for 15-20 minutes, so the batteries (2) 6 volts in series are always dead or weak when I go to start it. I might also be getting some voltage trickle from the voltage regulator. The batteries seem to hold better if I remove all the cables after use. I have just replaced both batteries.
My question is will changing the (2) 6 volt batteries (skinny type) wired in series, to (2) 12 volt batteries (skinny type) wired in parallel make much difference in cold starting. I fully understand it doubles the cranking amps, but do they last long enough to get it to start? Any other items I would have to change to do this?
