I have 1961 4010 Diesel that the right side positive battery terminal corrodes making a lot of residue on the cable/battery terminal in a short amount of time - a week to two weeks. The negative terminal also corrodes but not to the extent of the positive terminal. At that point the tractor won't start until clean up the connections and then it starts well. The left side battery shows no signs of corrosion. Also, the negative right side battery terminal looks as thought it has melted with some of the lead winding up below the clamp on the cable. I have cleaned this up twice now but continues to reappear. The batteries were new in 2008 but when not in use (winter) i pull the cables off the batteries and put battery tenders on them. Maybe it needs new batteries but I do not want to put the in and have the same thing happen if there is something else wrong. Any ideas???
Thank you.
Thank you.
