4010 cam and injector pump
hardinfarms
I have my 4010 tore down at the moment. I am wanting to send the cam off and have it ground. Does anyone have a place they would recommend. I also would like to have the pump turned up and possible put larger lines on it if I would see any difference. This is my first go at messing with trying to get more out of a diesel. I am also adding a turbo to this tractor. I will only be using the tractor for messing around at a few local pulls. Any advice would be greatly appreciated.
Bud
A 4010 in the turbo class--Less than 400 cu. in.- rotary pump- 8 to 10000 lb. class, will be a tuff job to compete. 1066's-4020's-D-21's and the list goes on. If you want to have fun you can--Tuff class to win. Good luck.
I would look at getting a 466 from a combine. Will need a 4320 exhaust manifold. Then you will have a inline pump. As lso 55 series head flows better. Don't spend money on your block. Another option is changing it to a gas. NA . And pulling Antique. Didn't come out right. Can pull a 4010 NA in Antique in Southern Illinois rules. Someplaces.
I agree or at the least a newer 404 out of a 7700 combine or 4430/4630 tractor. A few minor mods need done to front for fan and hydraulic pump coupler but guys on here can help out on that
