4010 deisel governor
Hi guys, my 4010 is not idling right, it will either die or rev itself up. I was trying to hook up a disc and it reved itself up so high I thought it would blow before I ran over and pulled the kill knob. I had a gas ford that did that once and the bearings in the governor had flat spots that had to be replaced to fix it. Is it likely a similar problem on my deere?
Metering valve in inj pump is sticking
probably from debris (retainer ring particles).
Xs three, time for the injection pump to be serviced. Just did a 4020 pump last week the guy ran it so long the retainer pins were sheared off. Luckily he didn't seize the head/rotor and break the drive shaft..
