4010 fuel line
4010 guy
I have a 4010 diesel with Bendix injectors (the lareger ones - about 1.25 inches around and 6 inches long) and I'm having a problem with the return fuel leaking on the first cylinder - very front of the engine. I took the injector out and when re-assembled it, the return fuel had a strong leak. I replaced the brass washers that sit between the top of the injector and the fuel line and the fuel line and the injector bolt (the hollowed bolt that screws into the top of the injector). I examined all the parts to ensure there were no scratches, paint build-up, or other imprefections. I also examined the threads on both the bolt and the injector and found them to look normal. I also thought that maybe the bolt that screws into the injector might be "bottoming out" so i added an additional brass washer and still no change.
At this point, it would appear to me that the only thing i can do is replace the return fuel line - maybe it has a crack in it where the line turns up back to the fuel tank.
Does anyone out there have any suggestions or experienced a similar issue?
Thanks, Rick
I always use JD paint thinner to wash all the surfaces including the washers. Then blow dry everything. Any trace of fuel will automatically attract dust in the air and that is enough to cause a leak. Then always install the washers with the cupped side towards the line . Like this (I). Are you sure the line to the tank is clear ?
I had this very problem with my 4010. Tried what you have tried and nothing worked. I ended up using rubber o-rings instead of copper. the first time i did it the o-ring lasted about a week, but the oring on it now have lasted about a year. just another idea.
