4010 Gen light problem
I have a 1961 4010 with the original 24 volt electrical system. Everything worked fine when I bought the tractor. Recently I found that my GEN light would not illuminate with the
key switch in the on position as it should. The OIL light works fine. I found that the bulb was bad and I replaced it. Now I find that the light still will not illuminate in the
on position and when the engine is running the bulb will glow dim at an idle and bright at full throttle. I've checked all the wiring, replaced the key switch, had the generator
and voltage regulator professionally checked. I even checked all the connections and cleaned the grounds. I've polarized the regulator. I have the full service manual for the
4000 series tractors with the wiring diagrams. I've ohmed out the switch, both the original and the replacement and they check the same. I've got to be missing something simple,
but admit that I may not fully understand how the circuit works, simple as it seems. Somehow it seems that there has to be a feed voltage and return circuit to turn the GEN light
on with the key switch in the on position, and once the generator starts to produce output current the voltage should equalize on each side of the light causing it to turn off. I'm
not sure how this should work or what to check in order to determine the problem. I'm looking for an expert who may have been down this road before that might like to help me out.
I want to keep this tractor original and am not interested in changing it out to 12 volts or adding an ammeter gauge. I've even discussed this with my Deere dealer but they
couldn't help. If you could help or know someone who might be willing to help I'd much appreciate it. Thanks for reading this and your consideration.
You could have a charging circuit issue and/or battery issue. Start with the easy stuff first. Determine if your 24V generator is charging, - voltmeter across the batteries or from the generator or regulator. You should see 25-26 volts with engine at about 1,500 RPM's. How old are your batteries? Are they matched, same age, newly installed. Sometimes the two batteries may not be equally charged and can cause an issue. Charge-light issue is more more likely as described here and not a wiring problem. Check, learn and study the schematic in the service manual.
(quoted from post at 17:06:10 11/17/21)
First of all, the REGULATOR doesn't get "polarized", the GENERATOR does (even though the connections/jumpering is typically done at the regulator, for convenience).
Are the batteries, starter, generator and voltage regulator connected EXACTLY as when the tractor left the factory (you say you have a diagram)?
Checking at the key switch, with the black lead of a Voltmeter connected to a good chassis "ground" the "BATT A" terminal should read (-) 12 Volts (nominal) and the "BATT B" terminal should read (+) 12 Volts (nominal).
One side of the warning light is connected to the "GEN" terminal of the voltage regulator, the other side connects to the "GEN" terminal of the key switch.
There is a resistor of around 50 Ohms made as part of the key switch at the "GEN" terminal which allows the use of a 12 Volt lamp in this 24 Volt system.
Check the voltage readings at the key switch and let us know what you find, it would seem the indicator lamp is being fed (+) voltage from "BATT B" instead of (-) voltage from "BATT A".
If battery cables on rear post of batteries have been updated/ changed to one cable connecting both rear battery terminals then check that small ground wire(item 30) has good continuity that is attached from LH battery rear post to tractor frame.
This post was edited by Tx Jim on 11/18/2021 at 03:41 am.
I want to thank everyone that responded to me about the GEN light problem. After trying many different things I've finally found out what happened. I mentioned in my post that I had checked all the wiring. Well as it turns out I didn't check very well. Both batteries were new as of a month ago. I did have the generator and voltage regulator checked professionally and no problems were found. I replaced the start switch, found a new one at a Deere dealer and bought it. I rang out (ohm/continuity checked) the new switch before I put it in the tractor. I checked the old one and the readings were the same. I found that the light socket is not connected to ground, both terminals float. What kept confusing me was the diagram did not show a complete circuit for the GEN light. Finally started checking voltages with the tractor running and found that the generator was putting out 37 volts, but the batteries only showed 12.6, one positive, the other negative. There was no BATT voltage at the regulator. Turns out the wire from BATT A (left) to BATT on the regulator was open. I ran a new wire to replace the one in the loom. Still no help for the GEN light. Took the regulator pulled the cover and checked it. Found that from the GEN/ARM regulator terminal to the floating GND terminal on the regulator measured about 84 ohms. That GND terminal is also wired to the POS lug on BATT B, except that in my case that wire was also open in the loom. So I ran a new wire for it outside of the loom. After getting everything put back together I then had the GEN light on with the key in the on position. Started the tractor and found that the GEN light would go out when increasing the engine RPM above about 700. Everything works fine now. Thanks for all the help. Really odd that I had lost 2 wires and a bulb. I now have about 28 volts from the generator and 13.6 or so on each of the batteries referenced to ground. The GEN light comes on dim at an idle, but goes out above about 700 RPM. I believe that for some time the generator was not charging either battery. Glad I found this before I wore out the new batteries. I really appreciate all the comments and help, they kept me going in the right direction. I did draw out the circuit for the GEN light. Starting at tractor ground at the batteries, there is a cable to the positive side of BATT A (left side). The negative side connects to the starter switch terminal BATT A. That terminal is switched to one side of a 51 ohm resistor and its other side is connected to the GEN terminal of the switch. The switch GEN terminal connects to one side ot the GEN bulb. The other side runs to the GEN terminal on the regulator (this is one wire that I found open. The GEN terminal on the regulator runs through a coil to the NEG (floating ground) of the regulator. The GND terminal on the regulator connects by wire to the BATT B terminal on the switch, which is the second wire I found open. The BATT B terminal on the switch connects to the positive terminal on BATT B. the BATT B negative terminal is connected to tractor ground which completes the circuit. The GEN bulb then becomes a sort of ammeter for the system, which illuminates when the generator is not charging, dim for low charge, bright for none at all.
Happy to do it. Hope to make a schematic of the GEN light circuit by itself. What the Deere schematic leaves out (in the 4000 Series Service Manual) is the switch functions,
meaning what connects to what. It also the return path through the voltage regulator is not clear. I guess a really good electrical engineer who understands what goes on in the
inside of the voltage regulator would scoff at my comment.
Regardless, I was very pleased to figure this out, but must point out that one of the comments I received back did point out that the return path does go through the voltage
regulator and to the positive terminal on BATT B. I did miss that.
Now, my next project will be to figure out a way or find out what is wrong with my other 4010 that has been converted to 12 volts and an alternator, because the GEN light does not
work on it either. I would like to have an indication of some sort that my batteries (2 parallel connected) are being charged.
I'm on a mission now, and while it might take a bit, I'm going to do my best to figure this out as well.
Wondering if Ole John T Electrical Engineer is still around? He used to post on YT about electrical problems in the 2 cylinders.
Thanks for reading.
