I just got a good running 4010 JD diesel tractor 1963 model. All hydraulics work good i thought. . But i put a loader on it a GB 900 high lift. Brand new closed center hydraulic double handle valve. As of now
i just plugged into rear remotes but i will change that later. Now i hooked it all up and the bucket works fine but when i try to lift the loader cylinder it kills the tractor. After that i thought maybe bad
valve so i hook the loader cylinders direct in the rear remote and the same thing. I checked my preassure with hydrailic gauge plugged into outlets and i have 2200. Im thinking i need to rebuild the loader
cylinders. And after the tractor dies from trying the loader cylinders the tractor will just crank and run a few minutes and then die over and over again . I blew the return line out it was clean . if i have
not used the hydraulics the tractor will run fine for a long time with no problems
